Hello,
In FME 2023 , in the AreaOnAreaOverlayer transformer the tolérance = “None” parameter has been removed. There only option of “Automatic” or “Custom value”.
Question : if there was Tolerance = “none” in pre FME 2023 .fmw scripts, should we use Custom Value = 0 to have the same result as tolérance = none or “Automatic”?
Thanks
Best answer by evieatsafe
