Using MAPI Instead of IMAP with FME Server notifications/publications
  • Sep 23, 2022 3:36 PM UTC
  • 52 views
agelfert
Forum|alt.badge.img+8
Has anyone had to switch existing notifications/publications in FME Server from IMAP which is easily configured in the web UI to MAPI? Is there a way without having to roll your own using custom code? I don't see any such options in FME 2020, nor in 2022 that I'm currently spinning up.
I'm being told I need to make that switch! Lucky me 😫
siennaatsafe
Forum|alt.badge.img+12
Hi @agelfert​
I've responded to you via a support case but thought I would follow up here as well.
If anyone else is looking for us to support MAPI, please file a support case and ask to be added to the internal ticket: FMESERVER-19032
Unfortunately, the only workaround in FME I can think of would be to use Python in a workspace. However, someone else may have other ideas.
Sorry for the bad news!
agelfert
  • Oct 12, 2022 1:13 AM UTC
Got this figured out with the help from Safe support. There is a patch for v2022.2.
