Triggering an automation when a job has been successfully completed WITH error messages.
  • Dec 11, 2023 11:59 AM UTC
  • 129 views
rickklopping
Hi everyone,
I'm looking for a way to trigger an automation once a job has been SUCCESSFULLY completed BUT contains errors. See job 56207 in the attachment as an example. The automation itself should then initiate another job.
So far, I haven't found a successful way to accomplish this seamlessly and efficiently. I've considered monitoring "/FME_SHAREDRESOURCE_LOG/engine/current/jobs" through an automation, but since I want it to automatically start a new job, it creates an infinite loop.
The system events 'Error Message Logged' and 'Warning Message Logged' also do not allow me to trigger a new job via automations based on my conditions.
I'm curious to hear your insights.
  • Dec 11, 2023 12:54 PM UTC
It depends on how this job was submitted. If it's by another automation, there's a failure "x" output port of the workspace runner widget. You can then use this to either trigger a notification or a webhook. If the job was submitted by a schedule, the REST or the jobsubmitter web service, then you can also associate a notification with the job that is triggered if the job fails.
