Triggering an automation pre 2022.2 ?
  • Dec 13, 2022 8:02 AM UTC
  • 99 views
lifalin2016
Forum|alt.badge.img+41
Hi all.
2022.2 introduces triggering an automation from a webapp, in addition to triggering automations in numerous ways already defined.
One such triggering is "FME Server Topic notified".
Can I create a workspace, uploading it to FME Server, and have this emit such a (custom) topic, in effect triggering the automation to run ?
If so, I could potentially create a webapp for such a workspace, and achieve the same functionality, couldn't I ?
Alas, there are no immidiate transformers that allows such emission, but workspace FME Server Parameters include FME_TOPIC and FME_TOPIC_MESSAGE. Can they be used for this, and if so, how ?
Or must I resort to using the REST interface ??
Best answer by david_r
I'm not quite sure I understand the question correctly, but you can either use the FMEServerNotifier transformer or the REST API to trigger a topic, which in turn would start any automation attached to the same topic.
  • Dec 13, 2022 9:41 AM UTC
lifalin2016
  • Dec 13, 2022 1:53 PM UTC
Ah, so there was a transformer for this. I typed "topic", and got nothing. The transformer naming got me again :-)
I did get it to work with the REST API, but this is much nicer.
Triggering automation in 2020.2 is indeeed possible, and surprisingly easy and straight forward. I even published a simple workspace designed to just post any topic, and I'm using this to trigger the automations in question (I have 4 automations with the same trigger).
