This FME edition does not recognize the `RasterObjectDetectFactory' factory
  • Nov 25, 2020 9:01 AM UTC
  • 5 replies
  • 366 views
Hi! I created a workbench in FME Desktop 2019.1 (build 19608) that uses `RasterObjectDetectFactory'. Everything works fine in desktop, but when I try to run it in FME Server I get the following message. FME server is running the same version and build as desktop.
  • "Library 'D:\\FMEServer\\Server\\fme\\plugins/opencv/rasterobjectdetectfactory.dll' was found but could not be loaded. Ensure that all the dependent modules exist for this library"
  • This FME edition does not recognize the `RasterObjectDetectFactory' factory. Please ensure that the current platform supports this factory, the factory name is spelled correctly, and that you have installed all required plug-ins
What's wrong?
nampreetatsafe
Forum|alt.badge.img+14
Are you using a 32-bit or 64-bit edition of FME Server?  I noticed that the RasterObjectDetector isn't available with FME Desktop 32-bit editions.
I'm using 64-bit edition of both FME Server and FME Desktop. The only thing I can think of is that I have FME Desktop 2019.1 and 2019.2 installed on the same machine. Could that be the cause?
nampreetatsafe
Hi @tommystalnacke0​: 2019.1 vs 2019.2 should cause an issue. Are you able to attach your full log file here for us to look at?
nampreetatsafe
@tommystalnacke0​ : I asked the development team if there any other dependencies besides the ensureing that you are using 64-bit FME. Can you confirm that you have <FMEServerDir>Server/fme/plugins/opencv/plugins/opencv/opencvfmeutil.dll in your FME Server installation? Also a full log file might help. Thanks.
Was there a resolution to this?
i am getting the same error message when attempting to use the RasterObjectDetectFactory using FME Server 2021 (64bit). No issues using FME Destop 2021.01(64bit).
I’ve checked the FME Server installation and the ‘<FMEServerDir>Server/fme/plugins/opencv/plugins/opencv/opencvfmeutil.dll’ is there.
Thanks
