Is there any limitation for Job log?
  • May 10, 2023 4:29 AM UTC
  • 75 views
phanindrasafe
Hi Team,
Is there any limitations for size of job log. My job keep restarting if the job log reaches to 25 page.
Thank you
hkingsbury
Forum|alt.badge.img+73
  • May 10, 2023 8:50 PM UTC
No, there should be no limit, i've had 100s of pages for a job lo. The fact its restarting suggests that the engine running it is crashing.
By default, FME Server should try to run a job that crashes (not fails) three times (if my memory serves me correctly). So after the third try you log should give you some indication of whats gone wrong.
  • May 11, 2023 7:54 AM UTC
Also check that the disk isn't running full.
phanindrasafe
Thank you both for the responses. Unfortunately I am unable to find any information in log. I will try to re-ran the job again.
  • May 11, 2023 11:05 AM UTC
The job log should mention available disk space around line 30 or so. Also check for low disk space messages in the the server cleanup log, see Resources / Logs / Service / Current / fmecleanup.log
