How to email when a process is done in FME desktop?
  • Sep 18, 2020 6:24 PM UTC
  • 490 views
armando_amador
Forum|alt.badge.img+5
I would like to know how to properly set an Emailer to a workspace from FME Workbench to notify that is finished.
Best answer by danilo_fme
Hi @danilo_fme​ , thank you for your response!
It's a very nice article, however, I just want to know how to properly set the Emailer transformer to know when the process is completed.
Thanks your reply.
Is your Workspace a Writer file ?
If yes, instead a object Writer you can use the transformer FeatureWriter and after a Emailer transformer:
Emailer
danilo_fme
Forum|alt.badge.img+58
  • Sep 18, 2020 7:38 PM UTC
Hi @armando_amador​
The best solution is the use the transformer Emailer.
You can check this https://community.safe.com/s/article/sending-email-in-fme-fme-workbench-vs-fme-server
Thanks in Advance,
Danilo
armando_amador
Hi @armando_amador​
Thanks in Advance,
Danilo
danilo_fme
  • Sep 18, 2020 8:30 PM UTC
Thanks your reply.
Emailer
armando_amador
Great! That was what I needed.
Thank you!
