How to convert a shape file to dwg file according to a dwg library
  • Sep 23, 2020 12:44 PM UTC
  • 0 replies
  • 53 views
I need to convert a shape file to dwg file where each layer in the shape file has to have line style or symbol according to a library in the dwg. I see that I can use dwg styler but i need to import each layer separtely ,as i have more than 60 levels ,i need to divide my file to 60 files in order to do it also it doesn't take the color for the symbol from the dwg template file.Is there a way to do it in one file?
thanks in advance
