Hello FME users. Is FME capable of automating other software? I am processing photogrammetry and Lidar with a complicated software that requires a lot of repetitive steps which are more or less the same every time. Thank you!
  • Dec 29, 2021 4:29 PM UTC
  • 57 views
Best answer by jasonclemis
If you can run other process using CMD line then you can use the System Caller transformer to run the other process in FME, you can also set the order of process with this transformer.
  • Dec 29, 2021 4:40 PM UTC
Thanks for the quick reply! So command line only? What about regular Windows menus?
@maximusfuscus​ or any software that has a REST or SOAP API using HTTPCaller
Thank you very much! I'll dig into it.
