FME Server Directory Update
  • Jul 15, 2020 5:09 PM UTC
  • 22 views
How do I set the reader parameter to read the correct data directory on the server where the data is to be placed?
Forum|alt.badge.img+63
You can use the $FME_SHAREDRESOURCE_DATA parameter, it refers to the Data directory in the FME Server resources. If you need to go into subdirectories you can just add them after that parameter.
