directory watch: run the automation during the night
  • Apr 12, 2023 1:55 PM UTC
  • 47 views
vki
Forum|alt.badge.img+8
I would like my automation to watch a directory. If there's a update, then the rest of the automation runs, but only during the night.
I could use a directory watch trigger to run the automation immediately after a change, or use the schedule-trigger to run the automation during the night, but how can I combine those triggers?
Thanks, Vera
Best answer by redgeographics
I think you should use two automations. The first one on a schedule that then runs a workspace that uses a Rest API call to enable/disable the second automation, which is the one with the directory watch.
Forum|alt.badge.img+63
