Directory Watch 404 Error
  • Aug 29, 2017 10:42 PM UTC
  • 5 replies
  • 68 views
I am getting 404 Error when I click on the zipped file in the email, while doing Directory Watch Publisher Tutorial (2016). I am using 2017 FME Server.
Best answer by LizAtSafe
Hi @pholmes, I'm currently working on writing an updated version of that article series for 2017 which should be posted within the next couple of days.
The reason you are receiving this error is because the FMEServerJobSubmitter was changed between 2016 and 2017 and the $(output_path) parameter no longer exists.
A workaround for now until the article is posted:
In the AttributeCreator after the FMEServerJobSubmitter, for the download_link attribute enter:
$(HostName)/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_TEMP/filesys/convert_tool/output/@Value(_rootname).zip?accept=contents&token;=$(ServerToken)
If you don't have the HostName and Server Token user parameters set up, just replace it with your actual Host Name or localhost and your current Token.
Ensure that your FMEServerJobSubmitter is updated to the latest version if you are working from the workspace that was provided in the 2016 tutorial.
You might also have to change the DestDataset_GENERIC in the FMEServerJobSubmitter to
$(FME_SHAREDRESOURCE_TEMP)/convert_tool/output/@Value(_rootname).zip
Hopefully that helps you finish the tutorial. I will post the updated tutorial here once I have finished it.
-Liz
danilo_fme
Forum|alt.badge.img+58
  • Aug 29, 2017 11:39 PM UTC
Hi @pholmes, if you problem is zip file empty has a interesting link about this error 404: Error 404 and this link too Data Download.
Thanks,
Danilo
LizAtSafe
Forum|alt.badge.img+26
  • Aug 30, 2017 12:17 AM UTC
-Liz
  • Aug 31, 2017 4:15 PM UTC
Thank you!
LizAtSafe
  • Sep 28, 2017 9:18 PM UTC
Hi @pholmes an updated article for FME Server 2017 has been posted. Hope this helps
Directory Watch Publisher (2017)
  • Sep 28, 2017 9:22 PM UTC
@lizsanderson , thanks for the follow-up with article update. FYI, using your temp fix above everything worked great! Thanks again.
