Automation not Saving after upgrade to 2022.0.0.1
  • May 13, 2022 1:30 AM UTC
  • 10 replies
  • 104 views
jackyd
Forum|alt.badge.img+16
We updated our test server to 2022, from 2021, yesterday. Since then i have been unable to save an automation with a action to run a workspace.
I noted that an automation I had set up had lost its directory watch path after the update. I added the path a tried a saving but it seems to get stuck and just sits there with the spinning wheel going round. I left it last night when I left work and it was still spinning the wheel when I logged in this morning.
I have tried recreating the automation and had no trouble saving until I tried to an action to run a workspace.
I have tried republishing the work space, and using a different work space
The automation will save with just the directory watch trigger and a series of filter actions, but fails when I try to add a Run workspace action.
So I'm stumped
Best answer by hollyatsafe
Hi @jackyd​ ,
Our development team has implemented a fix for this issue. The fixed build is going to be released to safe.com/downloads tomorrow.
However, since you've just performed an upgrade we'd like to try and issue you a patch so you don't have to redo the entire installation process. Please can you let me know what platform you've deployed FME Server too? If Linux, please can you be specific e.g. Ubuntu 20.04 or 18.04, RHEL8, CentOS 7 etc
Hi @jackyd​ ,
Please find details on how to deploy the patch in this article under the Resolution: Option 1 section.
Hi @jackyd​ ,
I'm sorry to hear that you've encountered this problem, I've just installed 2022.0.0.1 on both a Windows and Linux machine but have not been able to reproduce the issue yet. Please could you provide the exact steps you followed or a screen recording to demonstrate the problem to help me troubleshoot?
Hi @jackyd​ ,
Hi @jackyd​ ,
Actually, I take my previous statement back. It looks like this issue will occur when an output key is used in the downstream action. I will be filing an issue for this and will update this post when I have more information.
jackyd
  • May 15, 2022 3:40 AM UTC
Thanks Holly :)
I look forward to your update, this is a real blocker for us.
Thanks Holly :)
Hi @jackyd​ ,
jackyd
  • May 16, 2022 10:54 PM UTC
Hi @jackyd​ ,
That is great news Holly,
We are running our server on Windows 2019
Cheers
Jacky
  • May 17, 2022 11:52 PM UTC
Hi @jackyd​ ,
Hi @jackyd​ ,
jackyd
  • May 18, 2022 12:05 AM UTC
Hi @jackyd​ ,
Thanks you so much Holly, I will let you know how we go.
Please pass on our thanks to everyone for the fast response on this one, as always, Safe being responsive to your users :)
jackyd
  • May 18, 2022 12:51 AM UTC
Hi @jackyd​ ,
Works perfectly, thank you :)
dellerbeck
Forum|alt.badge.img+7
  • May 20, 2022 4:44 PM UTC
When was the full install going to be released. We are currently testing and would rather do a full install and test before moving to production. I checked the downloads and it's still at the 22339 release.
Thanks!
Thanks!
Hi @dellerbeck​ ,
Great question! Sorry, we encountered some delay in the release and is now being targetted for next week, hopefully, Tuesday but it's possible there may be further delays so I'd set your sights on this being available at the end of next week.
