Writing mixed case attribute names for DBF file
  • May 12, 2016 10:11 PM UTC
  • 99 views
I am trying to create a DBF file. Even after setting Manual attribute definition, all the attribute names are forced to UpperCase instead of Mixed Case which I want. Please let me know if I am missing any parameter settings or if the answer of this issue is know.
Best answer by erik_jan
I expect you have the DBF file as part of the Shape writer.
Then the Writer parameters have the option to force uppercase attribute names.
Uncheck that setting:
erik_jan
Forum|alt.badge.img+26
  • May 12, 2016 10:16 PM UTC
  • May 13, 2016 2:18 PM UTC
Hi Erik, My DBF is not a part of shape file. Although, I can generate a shapefile writer based dbf without geometry,
Thanks,
