WorkspaceRunner woes: "BadNews"
  • Aug 1, 2017 7:09 AM UTC
  • 5 replies
  • 134 views
lifalin2016
Forum|alt.badge.img+42
I'm using FME to check the log files of previous runs, testing for errors.
I'm now getting notifications of errors in a set of log files, that has been generated by running a workspace via "WorkspaceRunner". The error is bogus, however, so it messes up my overview by cluttering it with false positives.
The dependent workspace is called with two parameters: the path of the (xml) file to check, and a path to the desired log file. This log file path contains a dash, so I get this error:
BADNEWS: String value `WorkspaceRunner_DanDas: Running FME Workspace xxxxx.fmw with command line:' contains invalid characters and could not be converted into an integer (stfutil.cpp:802)
A typical log file name may be: CONTROL ARWOS XML - TV-Inspektioner.log
How can I avoid having FME attempt to do a bogus subtraction in my string value ??
Cheers
Best answer by erik_jan
Hi @lifalin2016,
I have been running into the same issues.
So, I posted this idea:
clean-up-the-badnews-messaging
It seems some old BADNEWS messages are still around, even though they have no meaning anymore.
lifalin2016
  • Aug 1, 2017 8:10 AM UTC
I forgot to state, that it seems to work none-the-less, but the log file is littered with these "errors".
erik_jan
Forum|alt.badge.img+26
  • Aug 1, 2017 1:08 PM UTC
Hi @lifalin2016,
fmelizard
Forum|alt.badge.img+22
  • Aug 1, 2017 4:10 PM UTC
Hi @lifalin2016, normally we recommend keeping BADNEWS turned off. Please check out our article on it: The Badnews Function. However, should you want them to be changed/cleaned up, please up-vote @erik_jan's idea.
runneals
Forum|alt.badge.img+32
  • Aug 1, 2017 6:01 PM UTC
How do you do this on FME server?
lifalin2016
  • Aug 2, 2017 6:32 AM UTC
Hi Tia,
I think you're missing the point here. Debugging information should never be marked as "ERROR" (which it is in this case), but rather "DEBUG" or similar. Yes, I can turn it off, but then I might miss something, since the same option is used in _all_ runs (because it's set in the overall options dialog), not just for the ones being developed (i.e. in the workspace). Or am I missing something here ?
Besides, this particular error seems to be caused by a wrong assumption on FME's part. Why else would it complain about not being able to do an integer subtraction in a path name ??
Cheers.
And Ps. I'm not running an FME Server, just FME Desktop.
