WorkspaceRunner in FME 2018 has strange functionality with Filename (Multiple) value
  • Jan 16, 2019 11:37 PM UTC
  • 72 views
I'm having some trouble with the WorkspaceRunner transformer in FME 2018 windows 32 bit.
Say Workspace B contains a FeatureReader transformer. In Workspace B, create a published parameter called FileList with a filename (Multiple) and set this as the dataset field in the FeatureReader to read txt files. Set the value of FileList to C:\\temp\\a.txt,C:\\temp\\b.txt. I have no errors running workspace B as is.
Using FME 2018, I trigger workspace B using a WorkspaceRunner in Workspace A, I get an error which highlights the paths in the Filename (Multiple) parameter are not valid. It is using the same value as FileList (C:\\temp\\a.txt,C:\\temp\\b.txt) that is used in workspace b published parameter.
It seams that the WorkspaceRunner doesn't send through the FileList value correctly in FME 2018. I have examined the log files and can see that in 2012, the Command line arguments are different. See below for differences (notice the qutation marks missing in 2018):
FME 2012 log file:`--FileList' `""C:\\temp\\a.txt" "C:\\temp\\b.txt""'
FME 2018 log file: `--FileList' `C:\\temp\\a.txt,C:\\temp\\b.txt'
I also tried the following with abnormal results.
Open the WorkspaceRunner in FME 2018. In the FileList field set C:\\temp\\a.txt,C:\\temp\\b.txt as the value. Highlight the value (ctr-a) and then copy and paste it straight back in to the field. It then turns into "C:\\temp\\a.txt,C:\\temp\\b.txt".
Is this a bug or am I missing something here?
Forum|alt.badge.img+54
  • Jan 17, 2019 9:16 AM UTC
If you're passing a filename list as a published parameter you have to set it in the workspace runner in this sort of format
 ""D:\Folder1\File1.gz" "D:\Folder2\File2.gz""
https://knowledge.safe.com/questions/25387/specifying-multiple-filenames-as-a-source-paramete.html
https://knowledge.safe.com/questions/25278/use-an-attribute-containing-a-list-of-files-as-fea.html
Thanks for your reply.
If I directly copy:
and paste it into the WorkspaceRunner value in FME 2018, it does not stay that value. it turns into:
"D:\Folder1\File1.gz""","""D:\Folder2\File2.gz"
Notice the new quotation marks. Do you get similar results?
