Workspace runner add some Title info on cmd window
  • Jan 15, 2020 10:32 AM UTC
  • 90 views
tva
Forum|alt.badge.img+13
I'm running the WSR with 7 concurrent processes. Is there a way to add information to the opend cmd window to identify which window belongs to which processes?
I need to terminate from time to time a cmd as it's hanging but I can't identify know which window belongs to which process and I need to guess.
In a batch file I would add TITLE parameter in it. Can something similar be set for WSR?
Below screenshot shows 7 CMD's but no distinction between them is possible:
The provided command is too long to check in the taskmanager. The part to see the difference can't be set on the monitor:
Best answer by erik_jan
A simple way of doing this is using the SystemCaller and providing the Echo command.
Echo before Tester and Echo after Tester shown in this example:
sigtill
Forum|alt.badge.img+25
  • Jan 15, 2020 1:16 PM UTC
Hi @vat
I would consider looking at FMECloud (https://www.safe.com/fme/fme-cloud/) to run multiple workspaces.
If you have already considered that I would just use FME to create a batch file as mentioned and add the TITLE as you describe.
If you use a program like Process explorer (https://docs.microsoft.com/en-us/sysinternals/downloads/process-explorer ) you might be able to see much more details on the cmd.exe process - so you might find the right parameter there also.
erik_jan
Forum|alt.badge.img+26
  • Jan 15, 2020 3:23 PM UTC
