Warning: not all Stashed Objects that were registered were dropped before shutdown. This may cause instability
  • Oct 10, 2016 9:13 PM UTC
  • 65 views
How does this get remedied?
I rebooted my workstation and still get this message...
How do I get going again, please?
itay
Forum|alt.badge.img+19
  • Oct 11, 2016 5:59 AM UTC
Hi @pvaziri, difficult to say without any more details on your process, can you provide more information?
  • Oct 11, 2016 3:23 PM UTC
I'm running WorkSpaceRunner and I had to kill it. I thought something was still running when I started it again, but I still got the message after I killed the fme.exe process. I also shut down all FME Desktop and Data Inspector instances. And finally, I rebooted the machine and then tried running the WorkspaceRunner.
I didn't see any log diagnostics I could use before the warning. I moved on and created another workspace and that is working. However, I still don't know how I got this message in the first place (never seen it before).
Should it happen again, I'll attach the log.
Thanks,
Pete
tim_wood
Forum|alt.badge.img+8
  • Oct 26, 2016 4:24 PM UTC
I came across this question because I've just had the same message. In my case it was because I copied and pasted a group of Transformers plus Writer and connected a new Reader to them. However I didn't expose fme_basename in the new Reader and I'm using that in the Writer. Once I exposed fme_basename the translation runs fine.
