Visibility analysis with DEM
  • Apr 24, 2024 4:35 AM UTC
  • 155 views
arthy
Forum|alt.badge.img+8
I would like to perform a visbility analysis as I’m used to with the esri’s fonction arcpy.sa.Visibility.
I tried to build something and after goglling, I read this excellent post  which is not working for me because I’m currently bound with FME 2021.2 and the script  of this post uses a newer version.
Is there a way to perform a visbility analysis with FME 2021?
Currently it looks like the clipper is not able to work on TIN surface.
Any ideas?
arthy
  • Apr 24, 2024 4:37 AM UTC
@kailinatsafe and others?
crystalatsafe
Forum|alt.badge.img+32
Hi @arthy
I found this article - How to Clip TIN Surfaces.
Under FME 2021 or Prior - there is a workaround for clipping TIN surfaces in FME 2021.
I hope this helps!
Crystal
