VARCHAR2(2000) issue
  • Jan 29, 2018 1:46 PM UTC
  • 84 views
Hi All,
We are converting Oracle spatial(SDO Geometry) to ESRI SDE (ST Geometry) using FME. In my data, some feature classes having VARCHAR2(2000) attribute columns. Those feature classes I am not able to process. Once I change VARCHAR2(2000) to NCLOB it worked for me. But i need to completed process with VARCHAR2(2000) only. Could anyone can help on this?
oscard
Forum|alt.badge.img+23
  • Jan 29, 2018 1:58 PM UTC
Could you show us how you have set the varchar(2000) in the writer? Being an ESRI SDE I guess you have created a char with 2000 for width.
erik_jan
Forum|alt.badge.img+26
  • Jan 29, 2018 2:05 PM UTC
Could you use VARCHAR2(2000) instead? VARCHAR is an old and limited data type and should not be used.
  • Jan 30, 2018 5:49 AM UTC
Hi @oscard, I am creating feature class first with required columns using PythonCaller and arcpy.CreateFeatureclass_management. Then i am using this feature class in writer.
  • Jan 30, 2018 5:51 AM UTC
Hi @erik_jan, I am using VARCHAR2(2000) only, it was a typo error. I will correct it. Thank you.
