Using Parameter to start workspace
  • Aug 29, 2019 4:35 AM UTC
  • 101 views
deanhowell
Forum|alt.badge.img+24
Is there a way to have a parameter used to kick off the workspace?
What I want is to be able to run the workspace and have the user enter a value or list of values that are then passed to a bunch of tests which then control the running of the rest of the workspace.
  • Aug 29, 2019 7:26 AM UTC
You can activate "Set Workbench To Prompt Before Running Workspace" (the green question mark) which asks the user to enter or check the parameters of the workspace. If you want, you can then run tests on these parameters and if you are unhappy with the user input you can send them to a Terminator, maybe after first using an Emailer to point out their erroneous ways. :)
itay
Forum|alt.badge.img+19
  • Aug 29, 2019 10:01 AM UTC
Hi @deanhowell,
You might want to have a look at the FME Quick Translator after you created the workspace that by default prompts the user to enter published parameters.
This application is much more user friendly for non FME users to run and an added bonus is that the user cannot 'mess' with the workspace.
Hope this helps,
Itay
