Unicode error in fmeobject4net
  • Nov 27, 2018 3:12 PM UTC
  • 34 views
Hi,everybody ,I use the fmeobject4net to process a bit data,and use the c# samples priject code,then some log info is unrecognition charact .the code and the debug info as follow:
FMEO_LogCallbackFunc viewInitialized = new FMEO_LogCallbackFunc(LogCallBack);
fmelogfile.SetCallBack(viewInitialized);
public void LogCallBack(FMEOMessageLevel severity, String message)
// Following code to ensure thread safety to avoid the
// InvalidOperationException thrown by VS
// string str = ParseChCodeString(message);
if (this.txtlogbox.InvokeRequired)
Invoke(new FMEO_LogCallbackFunc(LogCallBack),
FMEOMessageLevel.Inform,
message);
else
txtlogbox.AppendText(message + Environment.NewLine);
and the output loginfo in my app as follow:
and i open the log file, it is right as folow :
how to resolve the problem? Somebody can help me?thanks
xiaomengatsafe
Forum|alt.badge.img+11
Hi @skylining, Unfortunately the screenshots of the log files you tried to post didn't come through. Would you mind trying to attach the actual logfiles instead?
