Unable to write to Sharepoint Online List
  • Mar 22, 2018 3:00 PM UTC
  • 115 views
Hi all,
I am using FME Workbench 2018.0 Build 18284.
I would like to run an update to sharepoint list on Sharepoint Online.
Readers:
  1. Sharepoint list using (http link to the sharepoint rather than https; using https would run into an "Error message 403- error authenticating via SAML" (log-in details are correct)
  2. Excel spreadheet with new lat/lon values
I am using a feature Merger to update lat/lon column in sharepoint list
Writer
the same Sharepoint List
- when specifying the url to http://XXXX.sharepoint.com/Projects/XXXX the translation runs into a Client-side error: '405 Client Error: Method Not Allowed for url: https://XXXX.sharepoint.com/Projects/XXXX/_api/contextinfo
I have not specified the above https url ending in _api/contextinfo
- when specifying the WRITER url to https the translation runs into the above 403 SAML error
Do you now of any ways to work around these errors or are they possibly solely due to my sharepoint security settings?
Thanks a lot for your advice!
@Mark2AtSafe
Best answer by carsonlam
We're currently having issues with SharePoint Online authentication, and working on a hotfix. This is tracked internally as PR82823.
carsonlam
Forum|alt.badge.img+7
  • Mar 22, 2018 6:13 PM UTC
  • Mar 23, 2018 9:59 AM UTC
Thank you.
