Unable to download "NoFeaturesTester" from FME Hub
  • Jan 23, 2020 9:37 AM UTC
  • 7 replies
  • 174 views
atle_hoidalen
Forum|alt.badge.img+3
Hi!
I have a workspace that I want to stop with a terminator if no features leaves a transformer. I have tried to download the "NoFeaturesTester" transformer from FME Hub but nothing happens when I try bringing it into my workspace. I have downloaded plenty transformers from FME Hub earlier without any problems.
  • Jan 23, 2020 9:40 AM UTC
I just tested with FME 2019.2 (win64) over a wonky cellular connection, worked fine for me.
Are you able to download any other custom transformers today?
  • Jan 23, 2020 9:44 AM UTC
If you cannot add the transformer in FME Workbench, try downloading directly from this page.
https://hub.safe.com/publishers/safe-lab/transformers/nofeaturestester
Currently the transformer requires FME 2019.1+
atle_hoidalen
Hi David, it's the strangest thing, I tried in an empty workspace, nothing happens. Tried with a different hub transformer, this worked fine. Tried again with the nofeaturestester, now it downloads. Tried the same in my existing workspace, same workflow did not work. Ended up copying the transformer from the emtpy workspace, this worked... :)
atle_hoidalen
Ok, I'm running 2019.0. That explaines my issue. Thanks.
sigtill
Forum|alt.badge.img+25
  • Jan 23, 2020 10:34 AM UTC
Is there anything in the logfile? If you have both downloaded a local one and trying to download the same one from the hub you get an error @atle_hoidalen
sigtill
  • Jan 23, 2020 10:36 AM UTC
Depending on which version you have of FME Desktop you will get a different version of the transformer. For instance if you have FME2018 you will get version 3.
atle_hoidalen
Thanks Sigbjørn, I downloaded version 3. It works. :)
