Type-To-Add Transformer
  • Jan 7, 2014 1:59 AM UTC
  • 6 replies
  • 73 views
Hi, i have been following the raster tutorial and working on clipping. The tutorial notes that i should be able to add a transformer by clicking in the white space but this only seems to allow me to add a constant.
Is someone able to help me understand what im doing wrong.
Thank you
Carolyn
Best answer by davideagle
Try watching this from exactly 2 minutes in to the video http://youtu.be/KbfAEYMDZZg I think what is being refered to is the "Quick Add" functionality where you click somewhere on the canvas and type for example "clipper" you'll see a list of possible transformers which you can arrow up or down between then press return or left mouse click to add it to the canvas.
fmelizard
Forum|alt.badge.img+22
  • Jan 7, 2014 6:35 AM UTC
Just start typing : Clipper on the canvas a list of available transformers will show.
I am not entierly sure about this but from FME 2011 and onward this functionality should be available.
Itay
  • Jan 7, 2014 6:53 AM UTC
Thank you, i have tried this but it doesn't work.
davideagle
Forum|alt.badge.img+21
  • Jan 13, 2014 3:07 PM UTC
davideagle
erik_jan
Forum|alt.badge.img+26
  • Jan 6, 2016 3:20 PM UTC
If you have a newer version of FME Desktop it should work.
Did you have a look at the FME options in the Tools menu.
It has a setting for Quick Add:
davideagle
  • Jan 6, 2016 4:02 PM UTC
Quick Add functionality was only available from FME 2010 I believe, so you might have an older version perhaps?
