To build a loop
  • Oct 15, 2013 9:25 AM UTC
  • 62 views
franco69
Forum|alt.badge.img+11
I'm very busy today and need FME training...;-)
I have three feature classes
in feature class A and feature class B i have features which have an attribute STAU_ID
the features which belongs together have the same STAU_ID but i have to split it in two feature classes because of geometric conditions.
Now i want to take the feature with STAU_ID = 1 from feature class A and intersect it with feature class C. The lines from feature class C which are in the result i intersect then with the feature from feature class B which have the STAU_ID = 1....that in one workflow
The i want a loop to do it with the features from feature class A and B which have STAU_ID = 2 and so on snd so on
I have to do in that way because features from feature class C can intersect more features from feature class A and B with different STAU_IDs ...but i want to set the attribute STAU_ID then to the features from feature class C....so i have to do a loop
So whats the perfect way to do this and tell FME that he should take the next higher STAU_ID in a loop?
Thanks guys you made my day
  • Oct 15, 2013 11:41 AM UTC
Hi again,   I maybe don't understand perfectly what you need to do, but I'll try guessing.   The result you need is: C which intersects both of A and B having the same STAU_ID; resultant C should have the STAU_ID as its attribute; if a C feature intersects multiple A B pairs having different STAU_IDs, multiple Cs will be created.   If my understanding is correct, I don't think you need a loop. One possible solution is like this image. "Goup By" prameter setting of the SpatialFilter is very important.
Takashi
  • Oct 15, 2013 12:10 PM UTC
In addition, if different "A" features cannot have same STAU_ID, you can remove the Counter and the DuplicateRemover.
