Supress translation log
  • Mar 18, 2024 2:39 PM UTC
  • 208 views
jmcarthur
Is there a setting to disable the translation log window from automatically popping up when running a workspace? I’ve disabled all logging and hidden the window, but it pops up as soon as I run. I’m trying to record the execution of the workspace for a presentation, and the window keeps getting in the way.
Best answer by ali-safe
Hi, @jmcarthur.
I’ve reproduced your problem with the Translation Log.
The only alternative I found that could be helpful was to go into FME Options > Toolbar > Windows drop-down and drag the Translation log Icon to the menu bar in that window. Then, when the workspace runs again, clicking the icon disables the translation log and hides it while the workspace runs.
Hope this helps!
You could also suggest this functionality as an idea in +Start a post (beside your profile) and selecting Idea.
hkingsbury
Forum|alt.badge.img+73
  • Mar 18, 2024 7:24 PM UTC
You could undock it and drag it to another screen
or collapse it all the way down
jmcarthur
  • Mar 18, 2024 7:48 PM UTC
That’s the workaround I’m using, but it’s not quite the solution I was hoping for. A checkbox in the settings for something like “show translation log on workspace run” would be great. Give me the ability to opt-in to this behavior. Besides, moving the undocked panel to another monitor when working remotely from a laptop is a bit...challenging.
ali-safe
Forum|alt.badge.img+24
  • Mar 21, 2024 4:20 PM UTC
Hi, @jmcarthur.
Hope this helps!
