subscrioption sftp doesn't work on FMEserver 2018.1.0.2
  • Oct 9, 2018 1:45 PM UTC
  • 73 views
I'm trying to connect to sftp server by creating subscription on FME server 2018.1.0.2 to upload some files to sftp server, but I get this error "Host name is invalid", however I use the same host name on WinSCP and works normally. what am I missing?
can someone please explain what shoudl I do and what steps I should take.
I flollowed the steps here
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/SFTP_Subscriber.htm
Thanks
Saman
nathanatsafe
Forum|alt.badge.img+9
Hi @samanazizgeomap, thanks for your question.
How have you specified the host name for you subscription? If your sftp site is accessed at something like sftp://ftp.myftpserver.com, the host name should be ftp.myftpserver.com in your subscription. In my testing keeping the sftp:// part resulted in the same "Host name is invalid" error for me.
Hope this helps.
Nathan
Hi Nathan, Thank you very much for your answer. actually I'm using sftp://ip-address, ip-address is numeric. I guess that cause the problem. I changed it to ftp.ip-address but of course it wouldn't work since it needs to be ftp.myserver.com. I will ask around if I get proper ftp link. but why FME server doesn't recognize ip-address? it's easy to open in WinSCP.
Thanks again.
Saman Aziz.
Hope this helps.
Nathan
Thanks again.
Saman Aziz
nathanatsafe
Thanks again.
Saman Aziz
@samanazizgeomap did you try just the ip-address as the host? It seems to work for me.
