Stored Web Connections on FME Server 2018
  • Dec 12, 2018 5:53 PM UTC
  • 56 views
Every once and a while our controller workspace is unable to run because it: "Failed to access FME Server web connection" . This web connection is the user name and password used in the FME Server Job Submitter transformer. This connection is a stored web connection on FME Server.
Can you provide any insight to why this might be?
Hi @shaundadev,
Sorry that you are running into this issue, could you report this problem here so we can open up a case to investigate this further. Please could you include a job log for when this connection failed as well as the fmeserver.log and fmeconnection.log (resources/logs/core).
