SQL Server to PostGIS change prefix
  • Feb 13, 2019 11:29 AM UTC
  • 82 views
oliver.morris
Forum|alt.badge.img+14
I have many tables in SQL Server under the 'dbo' schema that I would like to replicate to PostGIS under an 'sde' schema. I would like to do this using the dynamic schema functonality. How can I replace the dbo with sde in the fme_feature_type attribute while still bing able to associate the matching schema for the tables using the dynamic writer.
Thank you
Oliver
Please forgive the use of schema term - schema in sql server means something different to schema in FME.
Forum|alt.badge.img+63
You could try a StringReplacer on the fme_feature_type attribute.
oliver.morris
  • Feb 13, 2019 12:02 PM UTC
thanks @redgeographics I tried that but even through the table name is the correct the schema for the table (i.e. all the attribute fields) doesnt match with the amended fme_feature_type attribute.
So the tables already exist on the PostGIS side?
oliver.morris
  • Feb 13, 2019 2:25 PM UTC
Sorry no that tables do not exist in postgres. Hope these images help.
Thank you
SQL Server
Postgres
The FME workbench
