Specifying multiple filenames as a source parameter in a Workspace Runner
  • Apr 5, 2016 8:37 AM UTC
  • 100 views
Forum|alt.badge.img+54
I currently have a workspace that determines a file location, and then a workspace runner uses this as the source parameter for the 'child' workspace.
If I run the child workbench in isolation, I can specify multiple file locations and both source files are read.
e.g.
"D:\\Folder1\\File1.gz","D:\\Folder2\\File2.gz"
But if I try to use this as a parameter for the workspace runner, no output is read.
Is there a different syntax I should be using within the workspace runner?
Best answer by takashi
Hi @egomm, try this syntax - separate the quoted paths with whitespace and surround the entire string with double quotations.
""D:\Folder1\File1.gz" "D:\Folder2\File2.gz""
See also here: Use an attribute containing a list of files as FeatureReader Input Dataset
  • Apr 5, 2016 8:53 AM UTC
