Socrata Writer: HTTP 503 (None): Auth succeeded but view lookup failed --
  • Sep 28, 2020 9:20 PM UTC
  • 32 views
I have three database tables that I joined using the FeatureJoiner tool. I was able to use the CSV writer to produce a file on my desktop. However, when I use the Socrata writer to write to my Socrata platform. I am getting the following error message:
Socrata Writer: HTTP 503 (None): Auth succeeded but view lookup failed -- https://domain.com/api/publishing/v1/revision
SAFE.SOCRATA.SOCRATA2 writer: A fatal error has occurred. Check the logfile above for details
... Last line repeated 2 times ...
Translation FAILED with 4 error(s)
I am not sure why I am getting this error message. I used the Socrata writer last week. It worked fine. Credentials are saved. Since this a new dataset. I doubled check that the Socrata Writer has the appropriate fields selected: Feature Operation: Updated
Dataset Handling: Create If needed.
Any reason as to why I am getting this error message?
Thank you
nampreetatsafe
Forum|alt.badge.img+14
Hi @yoshi2shi​, I'm sorry your experiencing this error. I've converted this question to a Support Case since you had the connection working last week. I'm hoping one of our Experts can work with you to determine what is causing this error.
