Simple loop
  • Oct 14, 2013 9:49 AM UTC
  • 5 replies
  • 59 views
franco69
Forum|alt.badge.img+11
I have two line features which contains hundreds of lines...but some of them have the same ID's.....i will create a polygon with lines which have the same ID's....i know easy question, best way?
franco69
  • Oct 14, 2013 9:56 AM UTC
so for example select feature class one with 1 and feature class two with ID 1 and build apolygon and then a loop two ID 2 and so on....otherwise FME will build too much unnecessary polygons because lines are overlayed...
Thanks
fmelizard
Forum|alt.badge.img+22
  • Oct 14, 2013 10:04 AM UTC
I would try the polygon builder or area buldier with a group by (ID) if that results in uncorrect polygons, try to remove duplicates (geometry/ID)
franco69
  • Oct 14, 2013 10:30 AM UTC
i want only one run and then loop it...means select from feature class A feature with ST_ID = 1 and select from feature class B feature with ST_ID = 1 and create a polygon with the AREA Builder then take the features with and ID higher (means in this case ID = 2) and do that for ca. 1300 features....i need a loop....but how can i do that ?
  • Oct 14, 2013 11:02 AM UTC
I'm not sure why you need a loop. As Itay mentioned, if you specify ST_ID to "Group By" parameter of the AreaBuilder, it will create polygons separately according to ST_ID, at one run-time. A resultant polygon having ST_ID = N will be assembled from only lines having ST_ID = N.
Takashi
franco69
  • Oct 14, 2013 11:35 AM UTC
Hi folks,
thank you....was my fault to think i need a loop....with group by it gives me right result...thx
