Sharing: Detailed Profiling of Workspace Running Performance
  • May 12, 2014 11:07 AM UTC
  • 5 replies
  • 178 views
Hi all,
Try adding this line in your workspace header (Menu: Tools > Edit Header).
FME_PROFILE_RESULT_CSV  C:\\FME\\prifile_result.csv
Then run. A csv file describing detailed profiling of the workspace will be created, like this image.
Today a seminor on FME was held in Tokyo as an official activity of the World Tour in Japan, Kevin@Safe told us this secret directive. He also said that a user interface such as a button will be added to Workbench for this functionality in the near future.
I like this hot information very much, so would share with you!
Takashi
fmelizard
Forum|alt.badge.img+22
  • May 12, 2014 6:24 PM UTC
Hi Takashi,
This is great, now debugging would be a tad easy!
  • May 15, 2014 7:28 AM UTC
Hi Takashi,
excellent tip, thanks a lot for sharing.
David
  • May 21, 2014 1:39 PM UTC
Hi, open the Workspace Header editor (Menu: Tools > Edit Header), and add the line like this.
srg
Forum|alt.badge.img+10
  • Oct 27, 2014 6:23 AM UTC
Wonderful tip Takashi.
Are the column names in the csv affected by the options enabled/disabled through Tools>FME Options>Log File Defaults?
sigtill
Forum|alt.badge.img+25
  • Oct 28, 2019 9:22 AM UTC
Would be great if this was a settings option - instead of a "Workspace hack" so more people could find it.
