select if hook one side edge
  • Nov 11, 2019 11:00 AM UTC
  • 52 views
rakeshreddy0996
I have line like Road and points are like houses
i have fields like side and ID_T
in picture highlighted blue apts having same ID_T because hooking same named edge
side field , if it hook right get R or else get L
In above wrong is only single edge that highlighted red circle apts
I need to select which apts are hooking only one side
sigtill
Forum|alt.badge.img+25
  • Nov 11, 2019 11:30 AM UTC
Can you use the LeftRightSpatialCalculator to figure this out?
rakeshreddy0996
could you please brief i'm bcz i'm new to FME !
