Select by attributes with case sensitive and replacestring
  • Sep 3, 2019 5:47 PM UTC
  • 10 replies
  • 102 views
rakeshreddy0996
I have a table like below
select red highlighted data and replace at once without case sensitive
I need to change as like below table
Thanks in Advance.. _/\\_..
jdh
Forum|alt.badge.img+41
  • Sep 3, 2019 6:13 PM UTC
I would consider using the DateTimeConverter (formally DateFormatter). You may need to use conditionals and/or split your input data as you have multiple input formats.
See https://www.safe.com/blog/2017/08/yet-another-awesome-datetime-update-evangelist165/ for a blog post about it.
rakeshreddy0996
that data is not time formatting data it just mistake
some times we are getting other universal words like SUN MOON.....
jdh
  • Sep 3, 2019 6:27 PM UTC
If you want to turn FEB into 2, that's date formatting.
rakeshreddy0996
SOME OTHER DATA LIKE
jdh
  • Sep 3, 2019 6:34 PM UTC
Do you have a lookup table to say RPR is 2 or hit is 3?
rakeshreddy0996
there is no specific table just we use replace
jdh
  • Sep 3, 2019 6:48 PM UTC
In that case have a look at the StringPairReplacer (Case Sensitive: No)
pratap
Forum|alt.badge.img+12
  • Sep 4, 2019 4:20 AM UTC
There is no generic solution for this kind. Kindly find the workspace along with data used were attached to this thread. I have prepared based on the data you have presented.
For more data, you have to make sure the mapping because you are using JAN/jan/Raj=1
rakeshreddysafe.fmw
del.xlsx
gio
Forum|alt.badge.img+15
  • Sep 4, 2019 3:25 PM UTC
@rakeshreddy0996
@jdh
@pratap
Yes you can...as always ;)
You need to complete the dates first to get a valid date.
Then just read and write. In tcl we would say scan and format.
Here is a workspace.
You could replace the tcl by the fme datefunctions to achieve the same.
datumvariantennaardigits.fmw
I mostly use this for info.
https://www.tcl.tk/man/tcl8.6/TclCmd/clock.htm#M26
gio
  • Sep 4, 2019 3:38 PM UTC
addendum
@rakeshreddy0996
@jdh is correct. It boils down to date formatting
