second shared resourced folder - how do I access the paramater?
  • Feb 21, 2018 1:29 PM UTC
  • 61 views
annette2
Forum|alt.badge.img+11
Hi
I have made a second shared resource folder in the fmeServerConfig.txt file.
SHAREDRESOURCE_TYPE_8=FILE
SHAREDRESOURCE_NAME_8=FME_SHAREDRESOURCE_DATAADA
SHAREDRESOURCE_DISPLAYNAME_8=DataADA
SHAREDRESOURCE_DESCRIPTION_8=This shared resource is the Server data directory
SHAREDRESOURCE_ISMIGRATABLE_8=true SHAREDRESOURCE_DIR_8=G:/apps/ada
SHAREDRESOURCE_SECURITY_DEFAULT_ROLES_8=fmeadmin|fmeauthor|adaauthor
SHAREDRESOURCE_SECURITY_DEFAULT_OWNER_8=admin
I can see the resource in the GUI and give authorusers access etc. But I cannot figure out how to access the resource as an FME Server Parameter.
  • I cannot add a new FME Server Parameter in FME Desktop.
  • And if I just use the parameter FME_SHAREDRESOURCE_DATAADA I get an error when I run the workspace on FME Server:
Undefined macro `FME_SHAREDRESOURCE_DATAADA' dereferenced in file `BI\\ADADataSharetestd\\ADADataSharetestd.fmw'
Thanks,
Annette
richardatsafe
Hi @annette2,
I believe you will need to also add a line in the fmeEngineConfig.txt to allow your resource to be accesses that way.
MACRO_DEF FME_SHAREDRESOURCE_DATAADA"G:/apps/ada"
annette2
  • Mar 16, 2018 1:33 AM UTC
Hi @annette2,
Thanks Richard. This worked.
