SDF3 Reader, get ID-column
  • Feb 28, 2018 3:57 PM UTC
  • 0 replies
  • 14 views
marvin
Forum|alt.badge.img+4
Hi everyone,
I am trying to create a dynamic Workflow with a SDF3 Reader and Writer. The idea is to reproject sdf-files with different schemas.
The problem in that workflow is that the SDF3-Writer expects an identity column, but the ID-column names from my sdf-files are not equal. Because of that I can't use a static attribute. In addition I don't want to create a new attribute as identifier in the output-file.
Is there any way to get the name of the ID-column of the sdf-file dynamically?
kind regards and best wishes, Marvin
