Running Python script using the interpreter provided with FME
  • Nov 18, 2014 6:46 PM UTC
  • 76 views
jfd553
Hi, I need to run a python script outside FME and I wonder if it is possible to use the interpreter provided with FME instead of installing another version of the same interpreter on my system.
If it is possible, are there any examples of such usage ?
  • Nov 21, 2014 7:20 AM UTC
The Python interpreter embedded in FME seems not to be an independent executable program, so I don't think there is an easy way to use it outside of FME.
But in reverse, there is a way to import the "fmeobjects" module into a script which should be interpreted with an outside Python interpreter, if necessary.
Takashi
gio
Forum|alt.badge.img+15
  • Nov 21, 2014 1:49 PM UTC
can use idle? standard in the pythonfolder.
jfd553
  • Nov 21, 2014 3:57 PM UTC
What is idle? I can't find it in FME python folder...
