run second part of workspace only if updatedetector from 1st part finds changes?
  • Sep 7, 2017 4:30 AM UTC
  • 56 views
Workspace attached. The first part is the CAD_Parcels bookmark. The second part is the CAD_Properties bookmark. I only want to run CAD_Properties bookmark contents if there are any features in the Update, Insert or Delete ports from the CAD_Parcels bookmark.
I assume tester and workspacerunner may be in order. I have to turn this into a FME Server job submitter also.
mygis
Forum|alt.badge.img+14
  • Sep 7, 2017 5:20 AM UTC
Hi @richardtriesfme,
Have you looked into the FMEServerJobSubmitter transformer? Just connect it to the "updated" port of the ChangeDetector transformer (UpdateDetectorParcels in your case). But you need to create a new workspace and put in your CAD_Properties workflow.
You do not need to use the tester, just connect the "updated" port to the WorkspaceRunner or FMEServerJobSubmitter
Note: If you use FME desktop you should use the "WorkspaceRunner" transformer, however if you are using Server you should use the "FMEServerJobSubmitter" transformer
I hope this helps.
I hope this helps.
Thanks, I need to run the Workspace/FMEServerJobSubmitter runner only after the entire rest of the first workspace has ran as properties depends on the finalisation of the parcels results. Is this possible?
  • Sep 7, 2017 7:04 AM UTC
If you would use the FeatureReader to read features for the second part, all the processes can be performed within a single workspace.
  1. Connect a single Sampler to the Updated, Inserted, and Deleted ports of the UpdateDetector,
  2. sample only the first feature (Group By: <not set>, Sampling Rate: 1, Sampling Type: First N Features),
  3. connect between the Sampler and the FeatureReader. Only if a feature is output from the Sampler, the feature kicks off the FeatureReader.
mygis
  • Sep 7, 2017 7:17 AM UTC
@richardtriesfme, right after the ChangeDetector if you want to start the new workspace.
In my case I would use a different approach; I would just add a FeatureWriter after the ChangeDetector (updated port) to write/save the data "lccgis.CAD_PARCELS then a FeatureReader in the to read the "lccgis.CAD_PARCELS" at the beginning of the "CAD_Properties" group to continue the same process within the same workspace.
It would be great to consider creating custom transformers to group your transformers.
