Reverse attributes values
  • Apr 27, 2019 1:53 AM UTC
  • 132 views
samisnunu
Forum|alt.badge.img+15
This looks simple to do, but I had to use 2 BulkAttributeRenamer, 2 Counter, then a FeatureJoiner
for example, the below attributes values need to be flipped as the FROM_xx to be TO_xx as shown:
Source attributes:
FROM_X | FROM_Y| FROM_Z | TO_X | TO_Y |TO_Z
1|2|3|4|5|6
Output attributes:
4|5|6|1|2|3
Is there a better way to do it?
  • Apr 27, 2019 4:57 AM UTC
This might be a simpler way. The order of attributes in the AttributeManager setting is important.
samisnunu
  • Apr 28, 2019 1:18 AM UTC
Excellent!!
Many Thanks @takashi..this is way simpler,
However, I guess you meant to remove the _temp_ dummy attributes in the AttributeRemover instead.
