REST API - Run Job/Workspace with Notification by FMEServerEmailGenerator
  • Aug 28, 2018 12:35 PM UTC
  • 8 replies
  • 106 views
I have a problem with the fmerest/v3/transformations/submit service and I hope someone can help me. I have a very simple worflow set up in my fme-server process.
Creator -> FMEServerEmailGenerator -> TextFileWriter
I have set up Topic and Subscription as described and configured my FMEServerEmailGenerator with the right topic.
Now I can invoke my process over fme-server gui successfully but if I do it via rest, I dont receive an email anymore. From my understanding the email configuration should be done by the transformer in this case, so sending my necessary published parameters should be enougth:
{"publishedParameters":[{"name":"uploadMeasures","value":"No"},{"name":"uploadDailyAverages","value":"No"},{"name":"test","value":"Yes"},{"name":"testEmail","value":"foo@bar.com"},{"name":"DestDataset_TEXTLINE","value":"$(FME_SHAREDRESOURCE_DATA)/output.json"}]}
But somehow its not. In my results under request data I'm missing notification manager directives sections. So I had to google because I didn't found an example on this in the api docs (run process with notification).
Now I added
"NMDirectives":{"failureTopics":["FLIESSGEWAESSER_TEST"],"successTopics":["FLIESSGEWAESSER_TEST"]}
into my rest body abd now I receive an email but all settings of my FMEServerEmailGenerator are missing like template and title -> empty mail.
Can someone please help me? I'm loosing to much time on this.
Thank you
  • Aug 28, 2018 12:39 PM UTC
I know it's not exactly what you're asking, but have you considered using the Emailer transformer? Much easier to use, in my opinion.
  • Aug 28, 2018 1:02 PM UTC
I'm open for alternatives. Is it possible to configure Emailer to let fme-server do the job? Because this is what I would like to have. This is just a test configuration where I want to invoke my workbench and somehow give the requestor a simple message as feedback. I thought email would be easiest way because there are these build in solutions like FMEServerEmailGenerator or FMEServerNotifier but maybe I was wrong.
  • Aug 28, 2018 1:05 PM UTC
If you want to use the FMEServerEmailGenerator, you need to send the output to the FMEServerNotifier, triggering your outgoing email topic with the content set to the output from the FMEServerEmailGenerator.
  • Aug 28, 2018 1:23 PM UTC
This works if I run my workbench locally but I'm publishing this as a service to fme-server. So far I had the FMEServerEmailGenerator set up as described in the main message according to the documentation and was able to start the process on the server with email notification.
  • Aug 28, 2018 1:28 PM UTC
Not sure I understand, that pattern should work on FME Server as well. In fact, it was the way I always did it before the Emailer was introduced.
  • Aug 28, 2018 1:49 PM UTC
Okay, just to be sure I understood you correctly :) because I`m not a fme expert.
I have some transformer providing a text attribute. I give it as input to my FMEServerEmailGenerator which has following settings:
To: target email from published parameter
CC: some other email
Subject: some text
Content: my template with another published parameter build in
I send the output of FMEServerEmailGenerator to FMEServerNotifier with following parameters:
connection: connection to our fme-server pre-configured for us
topic: my topic
content: text_line_data attribute created by FMEServerEmailGenerator
Now when I publish my workspace I have to configure Job Submitter service and I don't have a writer anymore what are the settings in Edit... after Job Submitter.
I only receive emails if I set a topic here under "post topics on success" but in your setup FMEServerNotifier should do that right?
  • Aug 28, 2018 2:49 PM UTC
Subject: some text
topic: my topic
If I'm understanding you correctly, you've found one of the "warts" of the notification system (in my opinion), and you're certainly not the first to stumble on this.
In short: the jobsubmitter service behaves fundamentally different to the REST API.
Basically, when you publish the workspace and you define the Job Submitter settings in the publication wizard, these settings are only valid for the so-called jobsubmitter service, and not the REST interface. For the REST interface the topics configured for the jobsubmitter are not used and you have to specify them on each job submission via the NMDirectives (as you've seen). Also, you cannot specify that you want a particular writer as topic contents, as you can for the jobsubmitter service.
Which is why I prefer the Emailer if the email is not used for critical failure notifications: it's consistent and works the same way regardless of where and when :-)
  • Aug 28, 2018 2:57 PM UTC
Subject: some text
topic: my topic
To answer your specific question: If you use the FMEServerEmailGenerator + FMEServerNotifier and only invoke the workspace using the REST API, then you can simply ignore the advanced parameters in the publishing wizard, they won't be used anyway.
