Renaming attributes configuration in a custom transformer?
  • Jun 30, 2016 9:01 AM UTC
  • 11 replies
  • 136 views
lifalin2016
Forum|alt.badge.img+42
I've tried to wrap some specific functionality in a custom tranformer in Workbench, and have defined a parameter (in the custom transformer) to be the name of the new attribute containing the output I'm calculating.
I'm creating the value into a temp local attribute (for a reason, I'm deleting it at the end), but cannot apparently rename or copy this temp attribute to an attribute with the configured name ?
Cheers
Lars
Best answer by takashi
My usual (secret ;) trick is to use a BulkAttributeRenamer. This exposes the specified attribute name automatically.
lifalin2016
  • Jun 30, 2016 9:02 AM UTC
  • Jun 30, 2016 9:16 AM UTC
You can indeed rename an attribute in a custom transformer based on a published parameter, e.g. if your parameter is called "NewName":
What complicates it slightly, though, is that the attribute name "NewName" isn't automatically exposed (made visible) in the Workbench editor, you will have to do that manually using e.g. an AttributeExposer after calling the custom transformer.
  • Jun 30, 2016 9:24 AM UTC
  • Jun 30, 2016 9:45 AM UTC
Nice trick!
lifalin2016
  • Jun 30, 2016 12:06 PM UTC
Hi David,
No, that doesn't work, and I did try this before I posted.
I get the error: Undefined macro `NEW_NAME' dereferenced in file `C:\\Users\\lin\\Documents\\My FME Workspaces\\wb-xlate-1467288075556_12320'
Cheers
Lars
lifalin2016
  • Jun 30, 2016 12:10 PM UTC
Hi Takashi,
This doesn't work either.
Please note that I want to rename the attribute _inside_ the custom transformer, not outside.
Have either of you tried to run the workspace I attached with the changes ?
Cheers
Lars
  • Jun 30, 2016 12:13 PM UTC
Hi Takashi,
Cheers
Lars
please check this demo: test-rename-in-custom-transformer-2.fmw
  • Jun 30, 2016 12:17 PM UTC
Hi David,
Cheers
Lars
Worked perfectly when I tested it using FME 2016.1. The attribute gets renamed inside the custom transformer.
But I think Takashi's suggestion was even better than mine, so you might want to look at that first.
lifalin2016
  • Jul 1, 2016 6:35 AM UTC
Hi Takashi,
That works !
Which is strange, because I did exactly what you described and did here, and it didn't work for me !?!
Ah well, my motto in these cases is: You shouldn't strive to understand why something doesn't work, just rejoyce when it does :-D
And so I shall. Thanks again.
Cheers
Lars
lifalin2016
  • Jul 1, 2016 7:28 AM UTC
Hi Takashi,
That works !
Cheers
Lars
Ah, found my mistake. You used ".+", I entered ".*". Need stronger glasses :-)
  • Jul 1, 2016 8:12 AM UTC
Hi Takashi,
That works !
Cheers
Lars
Good to hear it works!
I also thought ".*" could work theoretically, but it doesn't work in fact. In my observation, available regex for the trick are:
These two regex were unavailable:
  • .* (this will not rename the attribute)
  • .*$ (surprisingly, this will concatenate two specified string)
I don't know the reason why the last two expressions don't work...
