Renaming a folder
  • Mar 26, 2019 12:20 PM UTC
  • 187 views
Hi All,
I wish to rename a folder name from ABC to XYZ. Do we have any simple way of renaming it without using any python script?
giosp
Forum|alt.badge.img+7
  • Mar 26, 2019 12:45 PM UTC
Hi, you can use a systemcaller transformer and do it by command line.
nielsgerrits
Forum|alt.badge.img+67
The syntax is:
REN [drive:][path]SourceMask TargetMask
Example...
ren "D:\tmp\test test\testold" "test new"
...will rename the folder "testold" at the path "D:\tmp\test test\" to "test new"
see: https://ss64.com/nt/ren.html
Thanks @giosp
Thanks for the answer. Can you also provide a solution for renaming bulk folders?
