Publishing testclause of TESTER factory
  • Jan 6, 2016 9:15 AM UTC
  • 34 views
femo
Hello,
i would like to do an attribute test on a certain criteria using the tester. Since the criteria varies (
geb8_32368_5745_2_TILE_1, geb8_32368_5745_TILE_2, etc.) , i would like to publish this criteria and then create a batchfile with individual command lines per criteria.
I have created a new published Parameter. Then i have tried to connect this Parameter to my testclause but i does not work.
femo
  • Jan 6, 2016 9:36 AM UTC
Well, i forgot to add this Image, hope you dig it:
  • Jan 6, 2016 10:32 AM UTC
I cannot find any wrong thing in your screenshot, except that there is an incomplete StringConcatenator. What happens when you run the workspace using Workbench?
femo
  • Jan 6, 2016 3:30 PM UTC
test-publish-tester.batpublish-tester.pdf
Well, i did the steps again quietly step by step. It works know! I do not know what was wrong. I have documented it, maybe it serves someone else.
Takashi, thanks a lot for you support!
