Published parameters and creator transformers
  • Sep 27, 2013 5:45 PM UTC
  • 41 views
Hello,
I would like to have a parameter that is set from data that is sent to it from a webpage. When you create a parameter the prompt asks for a prompt. I am not sure what to set here. I need to have the pararmenter look at the data sent from the web page and set that so a creator can use it to set parameters. I am fairly new to FME also so any help would be great thanks.
Best answer by takashi
I think this documentation is a good point to start learning published / private parameters. FME Workbench > About Published and Private Parameters http://docs.safe.com/fme/html/FME_Workbench/Default.htm#published_private_parameters.htm
Takashi
  • Sep 28, 2013 7:25 AM UTC
Takashi
