Open table with python caller
  • Jun 24, 2020 10:49 AM UTC
  • 5 replies
  • 67 views
Hello, I would like to be able to call a table in an sde according to the choice of the upstream user. And then retrieve the fields from this table.
Is it possible with PythonCaller? Thank you
  • Jun 24, 2020 12:11 PM UTC
Why not use a FeatureReader?
  • Jun 24, 2020 12:25 PM UTC
I doesn't work. I'm with Safe to see why but for the time being we don't know why i doesn't work. That's why I asked myself if it was possible to replace the FeatureReader by a pythoncaller
  • Jun 24, 2020 12:43 PM UTC
I would definitely recommend getting the regular reader/writer mechanisms in FME to work, because everything else is going to be a workaround and somewhat more of a hassle to maintain.
That said, it is possible to use Python-specific database modules to read directly from the underlying SDE database (e.g. Oracle or PostGIS), but you need to know what you're doing and dealing with the geometries is a bit of a hassle. I would definitely not recommend going that route unless you have a very specific reason and you know the why's and how's.
  • Jun 24, 2020 12:56 PM UTC
ok thank you david. I thought that was easier but ok i will wait a answer from Safe.
  • Jun 24, 2020 1:12 PM UTC
I think that is the best long-term solution, for sure.
