OGCGEOPACKAGE Reader doesn't recognise extension in capital .GPKG
  • Jan 31, 2022 10:36 AM UTC
  • 117 views
I received a geopackage named "test.GPKG". When I set up a reader I select OGC GeoPackage as format and browse for the dataset. I select "test.GPKG" and click "Parameters" to select the tables. But then I get a error message that no such file exists. FME does not recognise the extension when written in capital. In the message FME is looking for "test.GPKG.gpkg".
Solution: rename dataset to extention with lowercase letters. Like "test.gpkg". Then the tables are shown.
Question: Is this behavior wanted? Or should FME also recognise the extension written in uppercase letters?
Freek
  • Jan 31, 2022 4:22 PM UTC
Hi @vega1979​ , it seems that the OGC GeoPackage Encoding Standard requires file extension is ".gpkg", so I think the behavior - FME won't acknowledge ".GPKG" as an appropriate file extension - is intentional.
ogc-geopackage-encoding-standard-file-extension
caracadrian
Forum|alt.badge.img+23
  • Feb 1, 2022 5:42 AM UTC
The lower case is an OGC Standard.
The funny thing is that if you have an upper case extension and you declare it small case in the reader it just works. Both normal reader and FeatureReader have this behavior.
  • Feb 1, 2022 7:33 AM UTC
Hi @Takashi Iijima​, thank you very much for your answer. It is clear that the lower case extension is intentional. I contacted my client to look in to this. What application do they use that is causing the uppercase extension.
Thanks.
  • Feb 1, 2022 7:34 AM UTC
Hi @caracadrian​ , good to see you have the same experiance as I did. Thanks for conferming it OGC standard.
