Not labeling all shapes
  • Mar 20, 2015 4:36 PM UTC
  • 51 views
Hello,
I am new to FME and working on a project...  I have merged a zoning polygons together based on their application number. I am now labelling them, there is just one problem, in a couple applications, there are 2 seperate shapes that require the same label, but only one is being labelled. I am using the 'CenteredLabelAdder' transformer.
What am I doing wrong?
Thanks for the help!
Iris
  • Mar 21, 2015 3:53 AM UTC
Hi Iris,
If the two shapes originally contain same label text, you can create labels before merging them.
Otherwise - i.e. if the label text has been added after merging, consider to re-decomposing them into single shapes by the Deaggregator before labelling.
Takashi
gio
Forum|alt.badge.img+15
  • Mar 25, 2015 2:53 PM UTC
Yes, sounds like aggregated objects, like Takashi says.
