When I run a workspace with the question mark so I am prompted for published parameters I get my usual list, but I cant select a private parameter as an option
However if I edit the published parameter value, I can set it to a private parameter as default.
Why cant I select this at runtime?
Cheers,
James
Best answer by andreaatsafe
Hi @jamesleversha,
Unfortunately, private parameters are not an option to be selected during Prompt and Run.
This is one of the differences between private vs published parameters. I would suggest converting the parameter you want to select to a published one.
Here's some more information about private vs published parameters.
